1994 Jaguar Vanden Plas Smokes black
1994 JAGUAR VANDEN PLAS
14,800 MILES • 6 CYL • 2WD • AUTOMATIC
MASTERMEX
I replaced the oxygen sensor, and the car continues smoking black, now the diagnosis little screen on the dash, say s "fail fuel 16", it s a sensor temperature, but were is it located?, you thing that by replaceing that sensor, the car will stop smoking black?
Sep 1, 2009 at 11:34 PM
DAVE H
  • 13,384 POSTS
Ensure Idle Air Control Valve (IACV) and overrun fuel cutoff operate with the throttle closed. Check throttle position sensor. Check voltage at mass airflow sensor pin No. 1 or 2 (zero volts) and pin No. 5 (12 volts). Check mass airflow sensor output voltage. For adjustment procedures, see ADJUSTMENTS article. Repair or replace as necessary.
Nov 27, 2009 at 7:54 AM
