1994 Jaguar Vanden Plas Fuel Failure codes
1994 JAGUAR VANDEN PLAS
95,800 MILES • 6 CYL • 2WD • AUTOMATIC
PAPABEAREMT
I had my check engine light come on today, I checked the code following the drivers manual instructions and it came up (fuel failure 69).
What could cause this and what do I do to repair it?
Matt
May 12, 2009 at 7:48 AM
DAVE H
  • 13,384 POSTS
DTC 69: PARK/NEUTRAL POSITION SWITCH (XJ6)
With transmission In Park or Neutral, measure voltage at terminal No. 3 (Red/Blue wire) of PCM Yellow connector. Voltage should not be present. If 5 volts is present, reset gear selector switches and/or check decoder module. Clear codes and retest
If 5 volts is not present, check for continuity between ground and terminal No. 3 (Red/Blue wire) of PCM Yellow connector. With transmission in Park or Neutral, continuity should exist (terminal No. 3 grounded). If continuity exists, replace PCM. If continuity does not exist, locate and repair open in Red/Blue wire.
Nov 27, 2009 at 6:57 AM
