I have a 92 jag vandenplas I have giving it a tune up changed the oil put a new alternator in. now I have bigger problems the car doesn't like to accelerate well at least not fast. it will if you hit the accelerator real slow. if you try to accelerate to fast it will pop through the air cleaner. next the car has great oil pressure for like the first 30 minutes it doesn't matter how you run it its fine after that it starts going down fast and will eventually go to nothing at a idle when you rev it up it goes back to a descent psi then comes back down but it takes like 30 minutes to 45 minutes for this to happen I haven't changed the sender yet I need to know if this is common or do you think I have bigger problems thanks. ps. when the pressure gets low it still sounds and runs fine.
Jan 29, 2009 at 3:29 PM
