1976 Jaguar Sovereign
I burned up a wheel bearing and the bearing cage welded it's self to the spindle or as the jag enthuisiast calls it the axle. I ordered a replacement axle and i am having difficult time removing the old one. can the assembly be heated to expand the fixture the axle is attached to? Is this a pressed fit? any info would be much appreciated. Luckily the axle is replaceable and Welsh Enterprises had one in stock it appears to be a taper fit with a stud and nylock nut to hold it in place.
Jun 1, 2009 at 11:19 AM
