2007 Jaguar S-Type Is rotor replacement when replacing pads
2007 JAGUAR S-TYPE
38,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRADFORDWBROWN
I have been told that in this car, when I replace the pads I MUST also replace the rotors. Is this true?
Jan 7, 2010 at 1:32 PM
DOCFIXIT
  • 18,828 POSTS
That's rubbish as long as rotor is not scored , wareped or thinner than tolerence then it is servicable.
Feb 28, 2021 at 2:45 PM
BRADFORDWBROWN
There is a ver small 'lip' on the outer edge of the rotor that needs to be removed but I cant imagine that normal turning of the rotors wouldnt correct that. The rotors look fine otherwise. This will be the first replacement of the pads and they are also in good shape, but beginning to get thin.
Thanks...
DOCFIXIT
  • 18,828 POSTS
That lip is very common with the use of semi-metalic pads should be enough rotor to cut smooth. Maybe next time not
