have been trying to compress the caliper
2007 JAGUAR S-TYPE
23,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVESLINE2
I have been trying to compress the caliper and the piston turns but does not compress. I have tried loosening the bleeder as well as brake fluid reservoir cap but doesn't seem to help
Oct 25, 2009 at 2:16 PM
Replacing front brake pads and rotors really isn't too hard. You can expect to get around 25,000 miles from a set of pads, but that is based on driving habits and terrain. Changing them yourself can save you a lot. If you get lifetime parts from a parts store and do it yourself, you shouldn't have to pay for brake pad replacement again.
First, here is a link that shows in general how the process is done:
Here are the directions specific to your vehicle. The attached pics correlate with the directions.
2007 Jaguar S-Type (X200) V6-3.0L
Brake Pads - Vehicles With: Standard Brakes, VIN Range: M45255->N52206
Vehicle Brakes and Traction Control Disc Brake System Brake Pad Service and Repair Procedures Front Disc Brake Brake Pads - Vehicles With: Standard Brakes, VIN Range: M45255->N52206
BRAKE PADS - VEHICLES WITH: STANDARD BRAKES, VIN RANGE: M45255->N52206
Brake Pads - Vehicles With: Standard Brakes, VIN Range: M45255->N52206 (70.40.02)
Removal
1. Remove both front wheels and tires.
pic 1
2. Detach the anti-lock brake (ABS) sensor wiring harness from the retaining clips.
pic 2
3. Rotate the brake caliper upwards.
^ Remove and discard the brake caliper lower retaining bolt.
^ Rotate the brake caliper upwards.
pic 3
4. Remove the brake pads.
Installation
pic 4
1. WARNING: Do not use compressed air to disperse brake dust into the atmosphere.
CAUTION: If the pistons are pushed back into the housing, brake fluid will be forced back into the brake fluid reservoir. I
CAUTION: Make sure the brake disc faces are clean before installation. I
CAUTION: Brake pads must always be replaced in axle sets.
To install, reverse the removal procedure.
^ Using a suitable tool, fully retract the brake caliper pistons.
^ Install a new brake caliper lower retaining bolt.
^ Tighten to 34 Nm.
_________________________________________
Brake Rotor Replacement
Brake Disc
Vehicle Brakes and Traction Control Disc Brake System Brake Rotor/Disc Service and Repair Procedures Front Standard Brakes Brake Disc
BRAKE DISC
Brake Disc Vehicles Without: Brembo Brakes
Removal
1. Remove the brake pads.
pic 5
2. CAUTION: The brake caliper must be supported at all times.
Detach the brake caliper and brake caliper anchor plate and secure to one side.
^ Remove and discard the brake caliper retaining bolts.
pic 6
3. NOTE: If the same brake disc is to be installed, the tip of a hub must be marked with a corresponding part of the brake disc for alignment.
Remove the brake disc.
^ Remove and discard the brake disc retaining clips.
Installation
pic 7
1. To install, reverse the removal procedure.
^ Tighten to 103 Nm.
I hope this helps. Let me know if you have other questions.
Take care and God Bless,
Feb 21, 2021 at 7:44 PM
