airbag light
2005 JAGUAR S-TYPE
49,000 MILES • 6 CYL • 2WD • AUTOMATIC
SOMEDUDE
My airbag sign came on randomly and every-time it stayed on the seat belt sign with the chime went on saying the seat belt was unfastened when the seat belt was fastened. So I took to the dealer and they could not find anything because it was not on when I was there. But they diagnosed it and gave me a paper with all the error code that was on the car. I have already changed the fuse on my car for the seat belt and air bag but it did not helped.
Here is the air bag sign blink pattern whenever it does that:
4 1 5 5 1 5 1 5 1 stayput
here is the code that I got from the dealer:
X204 engine Control Module DTC - Summary V6
Permanent P0480 Cooling Fan 1 Control Circuit Malfunction
Permanent P1260 Security Input - Engine Disable
Permanent P1582 Flight Recorder Data is Stored
Permanent P1632 Generator Charge System Failure/Generator Load Feedback Circuit Failure
Historic P0172 System Too Rich (Bank 1)
Historic P0175 System Too Rich (Bank 2)
Historic P0300 Random Misfire Detected
Historic P0301 Cylinder #1 Misfire Detected
Now I want to know how much would I need to shell out of my pocket to get my car error free or are these error not that big of a deal and are those history errors something that has been already fixed but the data is stored and what about the permanent ones? I want to fix it but want to know how much would I be looking at when I go to the dealer.
Thank you.
Apr 20, 2010 at 7:42 PM
DAVE H
  • 13,384 POSTS
If the vehicle is running good with no problems ..I would keep the record of these codes .. have the computer memory erased .. and drive the vehicle as normal .. if any of the same codes return repost for more assistance .. you may have a faulty seatbelt sensor in the clip .. or a wiring fault for the sensor
Apr 21, 2010 at 3:48 AM
SOMEDUDE
[quote:8a92c8f7c9="Dave H"]If the vehicle is running good with no problems ..I would keep the record of these codes .. have the computer memory erased .. and drive the vehicle as normal .. if any of the same codes return repost for more assistance .. you may have a faulty seatbelt sensor in the clip .. or a wiring fault for the sensor[/quote:8a92c8f7c9]
i will be going to the dealer very soon i will ask them to erase everything and ask them to see the seat belt sensor. but what about the air bag sign.
Apr 21, 2010 at 9:14 AM
DAVE H
  • 13,384 POSTS
the air bag sign may be due to a bad wire/sensor on the seatbelt buckle.. they are both part of the SRS (safety restraint system) and faults will display the airbag sign ...autozone or aamco will turn off the check engine light for you for free and read the codes free if it come's back on !!
Apr 22, 2010 at 2:44 AM
SOMEDUDE
[quote:6e8c514648="Dave H"]the air bag sign may be due to a bad wire/sensor on the seatbelt buckle.. they are both part of the SRS (safety restraint system) and faults will display the airbag sign ...autozone or aamco will turn off the check engine light for you for free and read the codes free if it come's back on !![/quote:6e8c514648]
The dealer said it has to do with the seat belt buckle and wants to replace it but wants 4 digit amount for it do that. Do you know where can I buy the oem seat belt buckle for the driver side with all the sensors.
Jun 5, 2010 at 2:36 PM
