2002 Jaguar S-Type Electrical Gremlins
2002 JAGUAR S-TYPE
101,000 MILES • V8 • 2WD • AUTOMATIC
DIGIDANA
We just got home from doing some running around and noticed that the automatic headlights didn't turn off after a while. When I went to check on it, i noticed that the dash lights were coming on off and on and the steering wheel was sliding in and out randomly. I tried putting the key in and the radio came on like it should, but it will not turn over. At all. I tried several times. We went to disconnect the battery and noticed standing water in the spare tire well. We've had a lot of rain lately, so apparently I have a leak somewhere back there. I'm guessing that a relay or fuse or something may have gotten wet? Since we were just driving around, I'm thinking that the water could have splashed on something that's not supposed to get wet? Its acting like I'm putting the key in and out...so could it be something with the ignition? We currently have the battery disconnected hoping things will dry out. Its a really strange gremlin. Seems to have a mind of its own.
Unrelated issue...after a while of running the heat, I smell burning rubber. Any ideas?
Thanks for any help you can give!
Dec 26, 2008 at 4:14 PM
Hi, yes is sounds like your battery has gone bad and the operating voltage is to low causing the "gremlins" Please check the battery surface voltage and replace as needed. Then recheck the alternator output if needed.
more info
https://www.2carpros.com/how_to/battery.htm
please let me know
Dec 27, 2008 at 7:41 PM
