P1: CHECK THE RESISTANCE OF THE VARIABLE CAMSHAFT TIMING OIL CONTROL SOLENOID
Switch the ignition switch to the OFF position.
Disconnect the left-hand variable camshaft timing oil control solenoid PI4.
Measure the resistance between the variable camshaft timing oil control solenoid electrical connector PI4 pin 1, (GW) and pin 2 (WP).
Is the resistance between 5 and 20 ohms?
-> Yes : GO to P2.
-> No : INSTALL a new left-hand variable camshaft timing oil control solenoid. For additional information, refer to VARIABLE CAMSHAFT TIMING (VCT) OIL CONTROL SOLENOID. CLEAR DTC. TEST the system for normal operation.
P2: CHECK THE VOLTAGE SUPPLY TO THE VARIABLE CAMSHAFT TIMING OIL CONTROL SOLENOID AT PIN 1
Switch the ignition switch to the RUN position.
Measure the resistance between the variable camshaft timing oil control solenoid electrical connector PI4 pin 1, (GW) and ground.
Is the voltage greater than 10.5 volts?
-> Yes : GO to P3.
-> No
REPAIR the circuit between the variable camshaft timing oil control solenoid electrical connector PI4 pin 1, (GW) and the spliced joint FHS 10. CLEAR DTC. TEST the system for normal operation.
P3: CHECK THE VARIABLE CAMSHAFT TIMING OIL CONTROL SOLENOID OUTPUT CIRCUIT FOR OPEN
Remove the powertrain control module (PCM). For additional information, refer to POWERTRAIN CONTROL MODULE (PCM).
Measure the resistance between the variable camshaft timing oil control solenoid electrical connector PI4 pin 2, (WP) and the powertrain control module electrical connector Pl1 pin 33, (WP).
Is the resistance greater than 10,000 ohms?
-> Yes : REPAIR the circuit between the variable camshaft timing oil control solenoid electrical connector PI4 pin 2, (WP) and the powertrain control module electrical connector Pl1 pin 33, (WP). INSTALL the powertrain control module (PCM). For additional information, refer to POWERTRAIN CONTROL MODULE (PCM). CLEAR DTC. TEST the system for normal operation.
-> No : GO to P4.
P4: CHECK THE VARIABLE CAMSHAFT TIMING OIL CONTROL SOLENOID OUTPUT CIRCUIT FOR SHORT TO GROUND
Measure the resistance between the variable camshaft timing oil control solenoid electrical connector PI4 pin 2, (WP) and ground.
Is the resistance less than 10,000 ohms?
-> No : INSTALL a new powertrain control module (PCM). For additional information, refer to POWERTRAIN CONTROL MODULE (PCM). CLEAR DTC. TEST the system for normal operation.
PINPOINT TEST Q: DTC P1633
Feb 24, 2010 at 7:01 PM
