I changed the A/C compressor, reciever dryer and serviced the A/C system on a 2001 jaguar s-type. there are no leaks in the system, and I added the correct amount of oil in the system. the problem is when the system is running with the vent in recycle mode the A/C cools really cold about 25 degrees cooler, but when the vent mode is turned to fresh air mode the A/C doesn';t cool very good it gets about 12 degrees cooler. also the high and low side pressures goes very high, but in vent mode while the vehicle is driving it seems to cool a little better, can you help me with this problem, thank you
May 19, 2010 at 11:12 PM
