2001 Jaguar S-Type Fuel Pump Replacment
2001 JAGUAR S-TYPE
56,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHRISDATA
One day while driving my car, The fuse for the fuel pump blow, I then replaced it with the 20amp nex to it to get me home, it ran for about a week then the car shout down. Ths time the fuse was was no blown, I susspect te fuel pump. could some onegive me information on replacing the fuel pump in thi 2001 S type Jaguar? Thanks so much
Dec 1, 2009 at 7:56 AM
DAVE H
  • 13,384 POSTS
Removal & Installation (S-Type)
Turn ignition off. Remove gas cap. Remove bottom rear seat cushion. Vehicle has 2 fuel pumps located inside fuel tank. One pump is located on left side of fuel tank, the other fuel pump is located on right side of fuel tank. Remove either left or right fuel pump access cover located under rear seat cushion.
Disconnect electrical connector and fuel lines from pump assembly. Using Sending Unit Wrench (J310-169), remove sending unit/fuel pump lock ring. Remove sending unit/fuel pump assembly from fuel tank. To install, reverse removal procedure. Tighten sending unit/fuel pump lock ring to specification. See TORQUE SPECIFICATIONS .
Jan 1, 2010 at 10:05 AM
