Wheel Bearing and Wheel Hub
Removal
Remove the brake disc.
Detach the anti-lock brake (ABS) sensor.
Remove and discard the retaining clip.
Detach the ABS sensor.
Remove and discard the O-ring seal.
Remove the wheel hub and bearing retaining bolts.
Remove the wheel hub and bearing.
Fig. 51: Removing Wheel Hub And Bearing
Courtesy of JAGUAR CARS, INC.
Installation
NOTE:Prior to applying sealer, clean the ABS sensor sealing surface and the ABS sensor aperture sealing surface.
NOTE:Install a new O-ring seal.
NOTE:Apply a 2.5mm bead of LOCTITE Ultra Blue 587 Silicone (RTV) sealer to the ABS sensor sealing surface.
NOTE:Install a new ABS sensor retaining clip.
To install, reverse the removal procedure.
Tighten to 90 N.m.
Mar 13, 2009 at 7:04 PM
