GENERAL PROCEDURES
Transmission Fluid Draining
Raise and support the vehicle.
Place a suitable container under the transmission drain plug.
Remove the transmission filler plug assembly.
Fig. 2: Removing & Installing Transmission Filler Plug
Courtesy of JAGUAR CARS, INC.
NOTE:If an integral problem is suspected, drain the fluid through a paper filter. A small amount of metal or friction particles may be found from normal wear. However, if excessive metal and friction particles are present, internal service will be required.
Fig. 3: Removing & Installing Transmission Drain Plug
Remove the transmission drain plug assembly and drain the transmission fluid.
Transmission Fluid Filling
Install the transmission drain plug assembly. Tighten to 26 Nm. See Fig. 3.
Remove the transmission fluid level plug from the center of the transmission drain plug assembly.
Fig. 4: Removing & Installing Fluid Level Plug
Fill the transmission until the fluid flows from the center of the transmission drain plug assembly. Use WSS-M2C 202B Automatic Transmission Fluid or equivalent meeting Jaguar specification.
Fig. 5: Filling Transmission
Install the transmission fluid level plug. Tighten to 10 Nm. See Fig. 4.
Install the filler plug. Tighten to 20 Nm. See Fig. 2.
Transmission Fluid Checking
Lower the vehicle.
Connect the PDU to the vehicle.
Measure the transmission fluid temperature.
Switch on the PDU and select 'Diagnostics'.
Enter the chassis number and other vehicle details.
Select 'Toolbox'.
From the 'Toolbox' menu select 'Powertrain'.
Connect the Multi Protocol Adaptor (MPA) and Download cable to the PDU and base station. Allow the PDU to load. Select 'Datalogger' from the menu. Disconnect the PDU from the base station and connect to the vehicle.
With the J-Gate shift selector in the Park position (P), select 'Enter' to start the 'Datalogger'.
Select the Transmission Oil Temperature 2 (TOT2) from the main menu.
The reading tolerance is from 80 °F to 120 °F, nominally 100 °F. If the value is greater than 120 °F the vehicle MUST be left to cool down. If the value is less than 80 °F then the vehicle MUST be driven slowly for approximately 500 meters at a time, checking that the PID reading is within the range specified. The target temperature when putting the vehicle on the ramp is 90 °F
Prepare to measure the transmission fluid temperature.
Start the engine and make sure the transmission fluid temperature is still within tolerance.
With the engine running and the foot brake applied move the J-Gate shift selector through 'P-R-N-D-4-3-2' and back to 'P' making sure that 'R' and 'D' have been selected on both occasions.
Select 'P' with the engine idling.
Raise the vehicle with the engine idling and carry out the transmission fluid level check.
Carry out the transmission fluid level check.
Remove the extension housing fill plug and the transmission fluid level plug. Place a suitable 1 liter container below the fluid level plug to retrieve any excess oil. The transmission fluid level will be either under or overfilled from the nominal condition.
If the vehicle is under filled only a few drips will occur. Oil must be added through the extension housing fill plug. Do not fill with more than 250 ml at a time until the fluid flows in a continuous stream. Install the transmission fluid level plug as soon as the stream starts to break up into drips.
If the vehicle is slightly overfilled fluid should flow in a continuous red stream. Install the transmission fluid level plug as soon as the stream starts to break up into drips. If more than 250 ml is retrieved go to the excessive overfill procedure below.
If the vehicle is excessively overfilled the fluid will appear almost pink rather than deep red as it flows, and more than 250 ml of fluid will be retrieved in the container. When all of the excess fluid has drained, install the fluid level plug. Switch the engine off for 30 minutes. By this time the fluid in the container should be a deep red color. If not, wait for another 30 minutes. Restart the engine then remove the fluid level plug. Add oil through the extension housing fill plug. Add no more than 250 ml at time until the fluid flows in a continuous stream. Install the transmission fluid level plug as soon as the stream starts to break up into drips.
Install the extension housing fill plug and fluid level plug.
Remove any excess transmission fluid.
Lower the vehicle.
Switch of the engine.
Remove the PDU.
Oct 25, 2009 at 9:35 AM
