Have a X type 3.0, at 25 mph I get a high pitched noise
2004 JAGUAR
ROTH
Other Category problem
2004 Other Jaguar Models V6 All Wheel Drive Automatic 32,456 miles
Have a X type 3.0, at 25 mph I get a high pitched noise. Have put transmission in neutral, shifted manually, applied emergency brake, nothing has stopped the noise. Any other speed you don't hear the noise.
Dec 6, 2007 at 5:33 PM
DAVE H
  • 13,384 POSTS
check the rear differential fluid !
Oct 31, 2009 at 7:23 PM
That should be fine, it only has 32k, I would think the front brake pads need to be replaced because the warning screemers are touching the brake rotor. Here is how to replace the front pads a rotors in case you want to do the job yourself. Check out the images (below). Let us know how it goes
Jul 6, 2024 at 5:54 PM
