2003 Other Jaguar Models recirculator function in climate co
2003 JAGUAR
JJRJAG02
Air Conditioning problem
2003 Other Jaguar Models V6 All Wheel Drive Automatic 37000 miles
2003 X-type. With the heating system operating, and the recirculator indicator off, my windows are fogging up. Operating the recirculator does not seem to result in any change, so I assume the door is stuck closed. Is this something I can repair? If so, how? Thank you.
Dec 7, 2007 at 8:24 AM
DAVE H
  • 13,384 POSTS
Defrost Vent/Register Blend Door Actuator
Removal
Remove the lower vent.
Detach the bulb holder.
Disconnect the defrost vent/register blend door actuator electrical connector.
Remove the defrost vent/register blend door actuator.
Remove the retaining screws.
Oct 31, 2009 at 7:29 PM
