2002 Other Jaguar Models What is this?
2002 JAGUAR
40,000 MILES • 6 CYL • AWD • AUTOMATIC
BILL WILLITTS
The message reads gear box fault. THe gear slips in 2nd or 3rd gear until you ease off the gas. Then it shifts.
What to do?
Jan 3, 2008 at 10:50 AM
FSTRANGER302
  • 117 POSTS
[quote:319c15f954="Bill Willitts"]Transmission problem
2002 Other Jaguar Models 6 cyl All Wheel Drive Automatic 40,000 miles
What to do?[/quote:319c15f954]
hello, the car has either a bad shifter cable causing the car not to be in gear all the way. should have it checked out and replaced if this is the problem. ore it has a mechanical failure of the trans. both could be adressed or checked out at the same time. probaly a bad shifter cable. let me know how it turns out.... rep points apreciated if infor helps
Jan 19, 2008 at 1:39 PM
