2002 Jaguar S-Type w/ 96,000 miles.
It appears that my AC is stuck on a single cold setting. Whenever I adjust the electronic temperature controls, the air temperature does not change.
The air temperature is currently rather cold...probably around 70 degrees. That is normally perfect for Florida where I live. Now that it is cooling off, however, I would like to warm it up a little.
Whenever I bump up the temperature degree, the air temperature stays just the same...even if I bump the electronic control up to 82 degrees...
Thanks for the help!!!
-MJ
-MJ
Oct 27, 2008 at 1:04 PM
