2002 Other Jaguar Models No Heat
2002 JAGUAR
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
UFMSEYMOUR
2002 Jaguar S-Type w/ 96,000 miles.
It appears that my AC is stuck on a single cold setting. Whenever I adjust the electronic temperature controls, the air temperature does not change.
The air temperature is currently rather cold...probably around 70 degrees. That is normally perfect for Florida where I live. Now that it is cooling off, however, I would like to warm it up a little.
Whenever I bump up the temperature degree, the air temperature stays just the same...even if I bump the electronic control up to 82 degrees...
Thanks for the help!!!
-MJ
Oct 27, 2008 at 1:04 PM
KHLOW2008
  • 41,814 POSTS
Hi ufmseymour, Thank you for the donation. Your symptoms refers to the heater not working and you need to check the following. 1. Clogged heater hoses or core. 2. Faulty Auxiliary Coolant Flow Pump. 3. Bad temperature control. 4. Faulty vent controls.
https://www.2carpros.com/forum/automotive_pictures/192750_HeaterAuxPump02Jaguar_1.jpg
Oct 29, 2008 at 11:00 AM
