2001 Other Jaguar Models transmission
2001 JAGUAR
50,000 MILES • V8 • 2WD • AUTOMATIC
JEFF SPONSEL
I have a 2001 Jaguar s type with 50000miles on it. I get rattle out of the transmission when you put it in gear. I do not get it when i put in park unless i bring the rpms up over 3000 the flywheel is good does anyone have any idea what is the cause.
Jan 10, 2008 at 1:41 PM
FSTRANGER302
  • 117 POSTS
[quote:bd5ac4eabc="jeff sponsel"]Transmission problem
2001 Other Jaguar Models V8 Two Wheel Drive Automatic 50000 miles
I have a 2001 Jaguar s type with 50000miles on it. I get rattle out of the transmission when you put it in gear. I do not get it when i put in park unless i bring the rpms up over 3000 the flywheel is good does anyone have any idea what is the cause.[/quote:bd5ac4eabc] i would check the torque converter nuts
they hold it tight to the fly wheel. on a 6 cyl there are 4 and a 8 cyl there are eight. it will rattle if the nuts are loose. let me know if this helps. rep points appreciated if this helps. thanks
Jan 19, 2008 at 1:26 PM
