Engine wont start up?
2001 CHRYSLER TOWN AND COUNTRY
130,000 MILES • 3.3L • 6 CYL • FWD • AUTOMATIC
MCLAUGHLIN0911
we were driving down interstate and it started to jolt a few miles later it just died the code read p0018,p1193,p1478,p032,p0123 we have replaced crank sencor ems coil and not sure what else and still nothing please help
Dec 1, 2014 at 12:18 PM
HMAC300
  • 48,601 POSTS
check auto shutdown relay with a like relay first. not fuel pump one though.p0018 means crank sensor to cam sensor correlation a pro has to fix that but it may be a broken timing chain the other codes may be from you trying to fix it. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Dec 1, 2014 at 1:25 PM
