Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
BMW
528
Ignition
Spark Plug
Replace/Remove
It's not getting any sparks in the plugs
1997 BMW 528
236,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
HDJSHSKAHSKSH
MEMBER
1 POST
FOLLOW
I can't get it to start at all we already changed the coil?
Feb 1, 2015 at 9:22 AM
CERTIFIED EXPERT
Have you checked the coil? Have you checked to see if there is power to the crank sensor?
Feb 2, 2015 at 5:27 AM
CERTIFIED EXPERT
I would replace the crankshaft impulse sensor which will cause this problem. We should run the codes as well to see if any are stored.
Here is the location of the sensor so you can swap it out which should fix the problem. Check out the images (below). Please let us know what happens.
Image (Click to enlarge)
Aug 2, 2024 at 11:34 AM
