In the video, am I looking at the bottom of the timing belt cover? If I am, you will need to remove the cover to inspect the pump. See pic below. Chances are that is where it is coming from.
Also, if you do need to replace the pump, also replace the belt at the same time unless it is newer.
Let me know what you find behind the cover.
See pic below.
May 24, 2023 at 9:20 PM
