If that is with the system off, the pressures should be equal or close to it. They call that (at rest) static pressure.
I would like to try to engage the compressor, but I'm somewhat concerned if there is no pressure on the low side. Once it is engaged, we could see if the pressures change to where they should be.
If you want to try it, just don't allow the compressor to stay engaged for too long, just enough to see what the pressures do.
I attached a pic below showing the compressor relay. On the relay, you will find four pins. On the plastic portion, there will be four numbers, 85, 86, 87, 30. If you place a jumper wire into pins 30 and 87, that will send power to the compressor clutch, and it should engage. If you are comfortable doing it, just make sure to wear eye protection at a minimum. You should be fine, but I'm not sure what is happening yet.
Here is a link that explains how to test a relay and its circuit. It provides a more detailed explanation of the circuits.
Let me know your thoughts and questions.
See pic below.
Oct 13, 2023 at 8:12 PM
