My motorhome sways a lot going around a curve or when cross wind hits it. It has the original front shocks on it. should i replace them and will that correct the sway problem? It is bad enough to possibly be dangerous. Also, would you just replace it with a OEM part or would you up grade to a heavier duty one? This is an Itasca Class A 30' long.
Jun 12, 2017 at 5:28 PM
