it wont go in gear with car on, no brake lights
1992 MERCURY MARQUIS
4.6L • V8 • RWD • AUTOMATIC
JEREMYANDLEAH
It will not go out of park with the key on. I have put it in neutral then start it. I allsoo lost brake, and reverse lights. I have replaced the neutral safety switch and the brake pedal switch.
Jun 2, 2014 at 9:55 PM
Are the brake lights working? Have you checked fuses?
Jun 3, 2014 at 4:55 AM
JEREMYANDLEAH
No my brake lights are not working neither are my reverse lights. Alll the. Fuses under hood seem ok which fuse would. Control shifting into gear aand. Lights?
Jun 3, 2014 at 5:19 AM
Without power from the brake light switch, the park lock solenoid won't release. Have you also checked fuses in the vehicle? Is there power to the brake light switch?
Jun 3, 2014 at 8:33 AM
