Starts but have to press accelerator to keep it running
2008 FORD EVEREST
131,674 MILES • 2.5L • 4 CYL • TURBO • 4WD • AUTOMATIC
R-NOLD GURNOTE
When i take my foot off the gas it will shut down. If I don't step the accelerator it will not properly start totally it only cranks.
Dec 19, 2019 at 6:46 PM
First, this vehicle isn't offered in the US, so my technical information is very limited. However, based on your description, it sounds like there is an issue with a component called an idle air control valve. If it is not allowing air to bypass the throttle plate at idle, the engine won't idle or start.
Take a look through these two links. They describe how to service one as well as replacement.
https://www.2carpros.com/articles/idle-air-control-valve-service
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Let me know if that helps.
Dec 20, 2019 at 8:32 PM
