Engine cranks but will not start?
2008 PONTIAC TORRENT
217,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
ACHUDSON
Recent computer replacement was about a month ago. Also put a new battery in it. Now the car won't start. It will turn over/crank. The fuel pump was just changed, pressure is good. Checked ignition coil it sparks, air filter is new. I don't see any loose wires or plugs. No access to a code reader at the moment. The security light is not on, already tried starting in neutral.
Aug 22, 2022 at 4:24 PM
So, the engine has fuel and spark, how does it sound when it is cranking over? Also does the engine have compression? You could have a clogged exhaust system. Can you take a short video of the engine cranking over so I can hear it? That way I can tell you if the engine is not good or not. You can upload it in your response.
This guide may help as well:
and
https://www.2carpros.com/articles/car-not-running-advanced
Aug 23, 2022 at 8:40 AM
