1993 Isuzu Truck starts sometimes and sometimes nothing
1993 ISUZU TRUCK
138,000 MILES • 4 CYL • 2WD • MANUAL
PERECHRR
Just replaced the battery and tightened the leads as tight as possible but they can still move a little. I depress the clutch and it starts sometimes two or three times in a row but then I get nothing but a click sometimes also. I hope this could be just change the battery lead connectors to fix but could it be something else like maybe the starter or solenoid, or relay or clutch safety switch, is there an easy way to check these if you do not have a voltage meter, barring taking them off and taking them do the auto parts?
Oct 30, 2010 at 6:55 PM
BILLYMAC
  • 2,204 POSTS
run power to the single wire post on the solenoid while it is not starting cranks solenoid is Ok.
clutch safety switch jumper wire across when truck does not start, if it starts switch is bad.
relays are not a common prob. Most likely if you can move the terminal ends this is your prob
Oct 30, 2010 at 7:01 PM
FYERMAN
i Have an 93 izuzu that has the same problem and it end up being the starter and i rebuilt it with new brass bushings and it worked great .u will have to do this every couple of years
Oct 8, 2012 at 2:31 AM
