VALVE CLEARANCE ADJUSTMENT
Ensure that rocker arm shaft brackets are tightened to specifications. Set No. 1 piston at TDC of compression stroke. Adjust clearance of No. 1 and No. 2 intake, and No. 1 and No. 3 exhaust valves. Turn crankshaft 360 degrees to place No. 4 piston on TDC of compression stroke. Adjust remaining valves.
VALVE CLEARANCE ADJUSTMENTS
Application.....In. (mm)
Cold
Intake .006 (.15)
Exhaust .010 (.25)
Hot
Intake .008 (.20)
Exhaust .012 (.30)
Apr 21, 2009 at 5:19 AM
