1986 Isuzu Truck 239000 miles
The truck will crank after cooling off but when it gets warm will not stay running. Have changed fuel filter, choke is working and have cleaned carb. I have checked for vacuum leaks and haven't found any. The truck drives fine but if I have to stop or put in the clutch it will die, cranks right back up and will run as long as I am giving it gas.
May 19, 2009 at 6:38 PM
