I had the front axle accuator and solenoid replaced a couple years ago after the TOD indicator light would flash continuously and not engage. My 4wheel TOD worked for a while and stopped. The indicator lights act as if it is working but the actuator is no engaging. The front drive shaft is engaging properly. I had a mechanic check the actuator and vacuum lines. They seemed to be fine. I don't know if the solenoid went out again or if the TOD control unit is fried. How can I check these components before replacing? If this turns out to be an expensive fix can I have this converted to a mechanical lockout hub?
Dec 2, 2008 at 9:43 AM
