2000 Isuzu Trooper Signal Lght
2000 ISUZU TROOPER
108,000 MILES • 6 CYL • FWD • AUTOMATIC
RAWILLIAMS
I just change my headlight bulb which was no problem. Now my signal light bulb on the driver side
is out and I don't have any idea how to change this one. Can you help me.
Robert
Nov 16, 2008 at 11:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove the lens backet set screw located at the top of the lens - this is done with the hood up. The backet connects the lens to the frame body. Gently place a large screw driver between the headlight lens and the trun singal lens and slowly pry the signal lens forward. The lens is held in place by a 3 - 4 inch tube that connects by presure into the frame. You'll need to apply enough presure to dis-engage the tube. It will pop out giving you access to all the lights contained in the lens. It's easy to pop it back in - remember to replace the set screw under the hood.
Nov 17, 2008 at 12:05 AM
