Time to replace on this vehicle. is it similar to front wheel drives,pop support,remove brake cable spindle nut, rotor, pop upper ball joint, tilt spindle, pull outer joint out of spindle,does the shaft w/joints then pop out of inner housings as in 80s era gm,ply. I would like to pull and pop in replace shafts?
Jun 27, 2009 at 12:42 AM
