2000 Isuzu Trooper Engine installed
2000 ISUZU TROOPER
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
WBURNS7868
I replaced the throttle position sensor and the engine installed after moving the shift selector handle from park to drive or reverse. The rpm gage indicates 600 rpm in park. Is there an adjustment for the cableless throttle?
Dec 28, 2008 at 6:46 PM
2CARPRO JACK
  • 11,533 POSTS
If it is "drive by wire" then you are at themercy of the motor that runs the throttle, there are no base adjustments or idle speed motors to replace, just the throttle body.Which TPS did you replace? there should be one on the gas peddle and one on the throttle body
Dec 30, 2008 at 9:08 AM
