2000 Isuzu Trooper Axle Ratio
2000 ISUZU TROOPER
11,500 MILES • 6 CYL • 2WD • AUTOMATIC
LUNKERLOVER
I never tow with this vehicle (not even hitch equipped), so could I drop my rear axle ratio from the stock 4.10 to say a 3.70 to improve my MPG? If so could you recommend a source for the gear?
Feb 6, 2009 at 5:28 PM
RACEFAN966
  • 5,029 POSTS
Ok yes you can put in different ratio's no problem and then all you will need to do is find a shop you trust to do it check them out make sure they do rearends and are fimilier with them don't forget to get an install kit. As for a place to buy Tom's Differentials or Randy's Ring and Pinion's your choice. Tom's is all USA made unless no other is available.
Feb 7, 2009 at 9:17 AM
