1996 Isuzu Trooper Thermostat
1996 ISUZU TROOPER
100,200 MILES • 4 CYL • 4WD • AUTOMATIC
KENYARDA
could the thermostat make the engine go bad?
Jan 25, 2010 at 7:08 PM
If the thermostat is stuck closed/shut it will not allow the coolant to flow causing the engine to overheat -could blow the headgasket crack the head and block-seized the engine/etc
Jan 25, 2010 at 7:23 PM
KENYARDA
is the head gasket expensive?
Jan 25, 2010 at 7:46 PM
Its the labor that's gonna hurt Note: labor charges varies with location could range from $70-$130.00 per hr. See below quotes
https://www.2carpros.com/forum/automotive_pictures/12900_trooper_1.jpg
Jan 25, 2010 at 8:53 PM
