1995 Isuzu Trooper oill problems
1995 ISUZU TROOPER
200,000 MILES • 6 CYL • 4WD • MANUAL
HARRISDERRICK
when i changed my spark plugs there was alot of oil on the old plugs. i was wondering if it was normal because i have changed lots of spark plungs and have never seen that before
May 11, 2009 at 9:13 PM
Oil being there could be valves and rings problem do an engine compression check
May 11, 2009 at 9:20 PM
JSP1014
  • 6 POSTS
on troopers there is a seal between the valve cover and the spark plugs, also there are problems with the spark plug wires not sealing to the valve cover correctly, so i recommend replacing the spark plug wires with a new OEM set, and replace the spark plug tube seals on the valve cover.
https://www.2carpros.com/forum/automotive_pictures/334397_6_1.jpg
https://www.2carpros.com/forum/automotive_pictures/334397_7_1.jpg
May 20, 2009 at 7:02 PM
HARRISDERRICK
does the seals come seperate from the wires
May 20, 2009 at 7:54 PM
