1994 Isuzu Trooper TCM
1994 ISUZU TROOPER
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
BLUEMOONLIGHT36
Thanks for the answer. You are very kind.
According to your answer below, I should try and find if something's wrong with the Torque Management Serial Line.
Question: Is there a way to identify this line? Color or something?
Thanks again.
Your answer:
the tranny control module (TCM) is behind the left side of dash, above kick panel.
code 37 : Torque Management Serial Line Faulty
Check wiring to the PCM and TCM. if OK suspect faulty TCM.
May 26, 2010 at 1:20 AM
BLUELIGHTNIN6
  • 16,542 POSTS
use test steps & schematic below with diagnostic scanner (aka Tech 1) to pinpoint the culprit..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2264.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_543.jpg
May 27, 2010 at 12:49 AM
