This car came with all of the paperwork on shop repairs. It had a new transmission in 2006. I get a check engine light always, only after driving about twenty miles, or twenty minutes. Also only and always when driving up hills or steep grades. It is a hard light to have checked because it always turns off in a slowing to stop situation once my speed slows below thirty mph. Confused? I am. I will try to say it more clearly. The light always comes on, it is just a matter of the situation which I am driving. If it is flat grade, and my speed is over thirty five mph it will come on mostly always after twenty minutes of driving. If the grade is steep or filled with up-hills it comes on much sooner. The light will then shut off every time while slowing, once my speed falls below thirty five. I thought is was the transmission, but the fluid is new and full. I also though it could be the pressure behind the gas cap? It runs good every day, it is just the light concerns me. Also, I took it up a mountain for skiing and once in 4X4 I shortly after received a red "trans fluid hi-temp" light. What is going on? Please help!
Jun 2, 2008 at 10:03 PM
