1993 Isuzu Trooper I have a fuel problem
1993 ISUZU TROOPER
212,000 MILES • 6 CYL • 4WD • MANUAL
KERRYGUNTER
My 1993 trooper sputters when taking off and while driving it wants to stall out. I changed the fuel filter and it is a little better but does the same thing. What else could it be? Im stuck and desperate.
Sep 1, 2010 at 1:00 PM
JACK_SWOGGER
  • 8 POSTS
its either clogged fuel injectors or it may be a spark issue. Pull one spark plug and check to see if you get spark, should be a bright blue flash, if its yellow or orange you should look into replacing the coil packs.
Sep 6, 2010 at 4:11 PM
