I just had to pull the tranny because the clutch went out. In the process I discovered that I had a coolant leak behind the flywheel. When I pulled it I found a small hole above the crank. I bought a manual but it didn't show the rear of the engine, so is that a small freeze plug or do I have bigger problems?
Mar 1, 2010 at 8:26 PM
