1993 Isuzu Trooper blinker
1993 ISUZU TROOPER
160,000 MILES • 6 CYL • 4WD • MANUAL
RYNO29063
i have replaced all bulbs, the flasher, and the fuse. every time i switch my left blinker on, it blows the fuse after 5 or 6 blinks. the right blinker blows it instantly. with both blinkers there is an electrical sound coming from the steering column. i replaced the 15 amp fuse with a 15 amp fuse. i've tried a heavier fuse and it works a little longer, but it heats up and blows eventually. i wasn't having any problems until i replaced my alternator.
Jan 27, 2009 at 10:57 AM
JASONRAY
  • 213 POSTS
Have you checked the output of the new alternator? Do that and make sure it's under 14.5 volts or so. It sounds like the turn signal switch itself is shorted internally. What happens when you turn the hazzard flashers on? I would look hard at the turn signal switch!!!
Jan 27, 2009 at 2:54 PM
