I have a drive train problem. Reman trans put in aprox 5 yrs ago. All of a sudden I now have a drag or slip problem. Checked fluids. Seemed fine but changed them anyway. No noise. Coasts no problems. Once up to speed cannot notice problem. The symtom occurs when a load is on the vehicle. This occurs in 2wd 4wd high but I do not seem to experience this in 4wd low. With vehicle on the ground in nuetral I can spin the cv of the right front with my hand. I cannot do this with the left front side. Is this a clutch slip problem or an 4 wheel drive type problem. There was no lead up to this event. Can I disable the 4 wd? I don't use it and am not sure it works anyway. Need to fix the problem myself if possible. Money is an issue for me. That is why I am still driving and fixing this vehicle.
Mar 19, 2010 at 10:01 AM
