1990 Isuzu Trooper rough idle
1990 ISUZU TROOPER
16,000 MILES • 4 CYL • 4WD • MANUAL
ORIGINBMR
90 isuzu trooper 4cyl 2.6L. 160,000. When I first start it up it sometimes acts like its going to stall or it does stall. Sometimes it doesnt idle rough. Everytime when it warms up slightly it acts like it stalls. After its completley warmed up it idles fine. Also I have white smoke coming out the exhaust. I dont know a lot about vehicles so I dont know if that has anything to do with the idling. I was told that smoke from exhaust is an internal engine problem. I just need some info before I go to a shop cause whatever the mechanics tells me I have to take his word because of my lack of knowledge. I just need to know what to expect.
Apr 8, 2008 at 10:31 AM
THIS IS MIKE
  • 686 POSTS
Check the coolant level when the engine is cold to see if you are loosing coolant. It sounds like a blown head gasket. The white smoke is caused by the coolant entering the combustion chamber and exiting thru the exhaust pipe.
Apr 9, 2008 at 12:40 PM
