#14 FUSE SHOWS 12 VOLTS WHEN IGNITION BUT RELAYS DO NOT ACTIVATE. i NEED TO KNOW WHERE IS THE DIODE THAT IS IN THE CIRCUIT TO RELAYS. RELAY WILL ACTIVATE IF I JUMPER 12 VOLTS TO THE COIL. VOLTAGE IS NOT PRESENT WHEN TURNING ON THE KEY AND SCHEMATIC INDICATES THAT FROM THE IGNITION TO COILS ON THE THE RELAYS IS DIRECT FEED
Nov 25, 2008 at 6:16 PM
