Welcome to 2CarPros.
Do me a favor, see if it will start for a couple seconds using starting fluid. If it does,. then we know it is a fuel related issue. Since you have spark, either it is fuel related or something internal has failed.
As far as the noise, is it the starter making the noise or the engine itself? You have me questioning of it is a timing belt issue. If it is a belt or timing issue, it won't start with starting fluid and we will need to confirm timing by performing a compression test.
The good news is that this isn't an interference engine, so no damage would have happened if the belt broke or jumped.
Here is a link you may find helpful. Also, if it is possible, record the engine cranking and upload it so I can hear what is happening.
Let me know what happens.
Oct 14, 2019 at 8:49 PM
