2000 Isuzu Rodeo Question Oil Leak
2000 ISUZU RODEO
12,000 MILES • 6 CYL • 4WD • AUTOMATIC
ABN509
My rodeo leaks oil at one side thru the spark plugs. I have to put in a quart eveyone 750 to 1000 miles. What is the problem?
Thank you
Mar 4, 2010 at 7:56 AM
2CARPRO JACK
  • 11,533 POSTS
It sounds as though the gaskets for the spark plug wells are bad, allowing oil to leak in.You will need to replace the entire valve cover gasket,the kit should come with the gaskets/seals for the plug wells.
Mar 4, 2010 at 8:02 AM
ABN509
Is it something that I can do or will it need to go the a shop
Mar 4, 2010 at 8:04 AM
2CARPRO JACK
  • 11,533 POSTS
Looks like the 3.5 is a little more complicated than the 3.2 engine. I guess it would depend on your mechanical ability.If you feel as though you can do it,I would suggest a bunch of digital pics as you take things apart, it is easier to look at a pic so you know exactly what you took off and where it goes
Mar 4, 2010 at 8:08 AM
ABN509
Can you give me a ball park price if I go to a mechanic?
Thank You
Mar 4, 2010 at 9:16 AM
2CARPRO JACK
  • 11,533 POSTS
Looks like Mitchells labor guide is about 2 hours of labor and the gasket set is around $35. You are looking around $200
Mar 4, 2010 at 8:15 PM
