1999 Isuzu Rodeo Question Valves
1999 ISUZU RODEO
166,100 MILES • 6 CYL • 2WD • AUTOMATIC
ZESTYSHERRY
  • 5 POSTS
I have a little white smoke from the exhaust pipe and when the radiator cap is off with the engine running the water bubbles. Someone told me that means I have a bad valve. Also 3 of the new plugs are black on the ends. It overheated once and it was only a matter of about a block maybe 2 blocks that I drove it and noticed the needle on hot. No smoke, noise or anything at the time. Also there was what appeared to be a metal gasket that knocked my timing belt off so it wouldn't start. Mechanic took it apart and found the piece of metal and a bolt. The metal has chewed up marks from the timing belt. He told me there was possible valve problems but he didn't think so. He "said" he tested it for head or head gasket problems and there was none, but possible valve problem. He knows I don'thave money to repair it so he said possible and didn't want to keep my car to further investigate. Is it a bad valve and how much money are we looking at?
Thanks for your time.
Sherry
Feb 24, 2010 at 11:33 PM
Hi zestysherry, Welcome to 2carpros and TY for the donation
Get it block and pressure tested posssible a blown headgasket cracked head or block or an intake leak-water bubbles sounds like exhaust gases making it into the cooling sysytem
A valve problem will not produce a white smoke unless its bluish in color-
Feb 25, 2010 at 12:01 AM
ZESTYSHERRY
  • 5 POSTS
The mechanic that put the timing belt in said possible bad valve. He told me he checked for cracked block and head or head gasket. How do you check for that? I was wondering if my son could do that for me. He can do some things but he hates this duel cam and the newer engines.
Thanks for your help.
Sherry
Feb 25, 2010 at 11:26 AM
You need to check with your auto parts store and check for a chek bloc or a cooling pressure tester, instructions are there.
Feb 25, 2010 at 4:04 PM
