Electrical problem
1999 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic 118k miles
Rear wiper ran continuously for a while - couldn't shut it off - finally blew a fuse. From then on every time ignition turns on the fuse blows. Long story made short - I have a new alarm/relay control unit and a new rear wiper motor assembly. Problem hasn't changed. If I unplug the wiper motor - fuse doesn't blow. I jumpered the wiper motor drive lines directly to the wiper motor without plugginng in the connector, leaving the internal "run" and "park" switches out of the circuit and the fuse doesn't blow. But the motor doesn't turn either. The "run" switch on the new motor (fresh out of the box) is closed, the "park" switch is open. Help!!
Aug 11, 2008 at 8:36 PM
