1999 Isuzu Rodeo Question diagnostic port
1999 ISUZU RODEO
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHIP34
When this vehicle went in for inspection the portable diagnostic tool worked and read the codes. When the mechanic hooked up the state computer to the car it read "the computer does not appear to be connected". The mechanic tried the diagnostic tool again and it worked, Then the state computer and nothing. The state computer then worked on another vehicle, he showed me everything and is a trusted known mechanic who admitted it didn't make any sense to him. I put a meter on the terminals and got only five volts from the red wire while the car was on. Should this be 12 volts? any thoughts, the vehicle can't pass unless this connection can be succesful. HELLLP!!!
Jun 20, 2008 at 2:28 PM
KHLOW2008
  • 41,814 POSTS
Hi Chip34,
Only pin No 16 would have 12v, the others should have 5 v.
Was the other vehicle tested the same model as yours? Sometimes certain makes of diagnostic equipment cannot read a certain model, have you done any changes to the ECM or related parts?
Jun 22, 2008 at 3:59 AM
